Dually Suspension \  FRONT ROTORS /HUB/SPINDLE
Dually Suspension Dually Tech
views 1071
replies 8
following 6
dragncru   +1y
WHAT KIND OF FRONT ROTOR/HUB IS BEING USED ON THE RED DUALLY AT LITTLE SHOP OF HORRORS. IT LOOKS MORE LIKE A STANDARD WHEEL TYPE HUB. IS IT MOUNTED ON THE DUALLY SPINDLE OR HAS THE SPINDLE BEEN CHANGED ALSO, IF SO WHAT KIND OF SPINDLE. HOW MUCH DOES THIS HELP TO PULL THE FRONT WHEELS IN WHEN BODYDROPPED ON SEMI'S TO CLEAR THE LUGNUTS FROM CONTACTING THE FENDERS.
tofnlows10   +1y
call little shop, dudes are cool, im sure they hook ya up!
rhmdually   +1y
Its probably just 3/4 ton hubs. they bolt right up to the dually spindles i beleive and bring the wheels in about three inches I think.
okcderek   +1y
3/4 ton brakes are what brings the wheel in more than spindles...
dragncru   +1y
Do the 3/4 ton hubs fit the dually spindle or does the spindle need to be changed to 3/4 ton also. Just trying to see if changing rotors/hub might be easier than changing control arms.
brianbgboy   +1y
we have been thru this topic too many times people! use the search function...
jcampbell1180   +1y
^^^Oooohhh...you're being a "search function Nazi".
Two words-
Caps. Lock.
brianbgboy   +1y
not really a nazi, just tired of posting on this subject, you know!!!!
jcampbell1180   +1y
Yup.
