Tubular Lowers!
15 following
kandykoated@rogers.com's avatar
Tubular Lowers!
lophat's avatar
lophat
Ok I am about ready to loose it with the front end of this truck. I am moving to the back while I figure this out. I need to know if anyone can make me a set of tubular lowers with a bag mount for the front of the 77?
I just need to know a price, and then i'll see if it's worth spending a shitload of time modifying the front lca's or not.
Holla!...pm or whatever.
thx guys.
jcampbell1180's avatar
jcampbell1180
I can make you a set.
I've got a little Lincoln wire feed and some old 3/4" gas line out back.
My welding skills are...eh...but I'm sure I could knock it out.
How's $1,000 sound? Cash up front, of course.
jeffrodamis's avatar
jeffrodamis
do you accept Piggly Wiggly coupons?
brianbgboy's avatar
brianbgboy
probably cheaper to modify the stockers. finish the back and get to fabricating!
huskerdually
Buy a set of these and cut out the crossmember that hangs past the frame and weld this in then you can move the top of the bag further up.
Copy
over
kshh
W
watahyahknow
ít seems that tubulairs aren't available anymore for the one ton's i had trevor look for them and he couln't find any .
i'm having some half ton strongarms adapted , from wat i understood the top ones wil fit normaly the bottom ones need to be drilled out to accept the larger balljoint of the one ton
low95xlt
try hittin up barely legal fabrication i know he is settin up to bag his dually around a 80's and i know he was plannin on makin a arms so give him a shout
lophat's avatar
lophat
Thx for the help guys. Ya I hit up BLF already and haven't heard anything back yet.
low95xlt
i would give them a call pmme if you need the number i know they dont get on here alot since taylor( jeebus) decided to do his ram up
bdydrped's avatar
bdydrped
did you get your business skills from the famous mike white from barnyard?
