Dually Suspension \  inner fenders of bed
Dually Suspension Dually Tech
views 1438
replies 11
ogre   +1y
I have a lowpro 16 on the truck now and when it lays it or the back is down theres a section that cuts into my inner tire. other than the obvious shortening of the axle what else could be done to eliminate this
low95xlt   +1y
either trim the lip that is hanging down or cut out ur fender wells and do trialer fenders or lift urs up and add metal
ogre   +1y
thats what i was thinkin but a birdie told me that if i cut them out then the bed would start to separate or somethin i think i may have misunderstood him
liljlowrider   +1y
i just cut mine and its been cut for about 5 years now and its still find...
ogre   +1y
do you have any pics so i can get an idea as to what all to cut out cuz im getting ready to put it back on stock tires till i muster up the two arms and a leg for the rig wheels
liljlowrider   +1y
once you take the tires off you will see a lip(kinda looks like the pinch weld under the cab) i cut it flush but just on the top where the tires would rub.. you should be able to see the rub marks to let you know where you need to cut.
ogre   +1y
and just cutting that will allow it to lay in the back on stock tires
liljlowrider   +1y
yea im laying with 22's and i still have my inner fenders.. which im runnin a 16 on the inside with a big ass tire..
ogre   +1y
k thanks man apparently the stock tires are same size as the 22 with lowpro so i just wanna get it setup as much as possible i already have to replace tires tho cuz that lip of which you speak has dug a groove all the way down to the belt on the inside tires
liljlowrider   +1y
what size tire is on your truck now?
