Dually Suspension \  whats the prefered front suspension mount? plates or cups?
Dually Suspension Dually Tech
views 1286
replies 13
following 5
mrwilliam   +1y
Well, Plates or cups? pro's and cons...
ec_dually   +1y
mine has cups...
huskerdually   +1y
His is a square and I think most guys use the plates. I plan on cutting the entire spring pocket out and using a universal bag mount, so I can run re8's.
mrwilliam   +1y
i have the 2600 firestones... i know, i know.. they are oldschool.... i think the plates sit lower or no?
jeffrodamis   +1y
be gotam sure to cut enough out..i thought i "mauled" my spring cups but when the re8s broke in they stretched enough to rub the pocket 2 inches above the top of the bag....so if your planning on stepping up alter, might as well cut it big while your in there. truck looks a lot better mr bill
mrwilliam   +1y
Thanks for the info Mr.Jeff... and the complament
dragnasty   +1y
Flat plates and recess the lower Aarm if you plan on running big wheels.
huskerdually   +1y
My way is going to be better.
dragnasty   +1y
You just want to do more work than needed.
huskerdually   +1y
Actually I am going to wait till i get further along to decide how I do it. I didn't think you could get an re8 to fit. Even with recessing it in the lower.
