I'm wondering if I run a 16 inside and a 22 outside on my '98, will I have to modify my rear dually fenders. I know that it would be narrower than running 2 of the 22's in the back, but is it narrow enough? And if it is narrow enough, is it so close that it might rub sometimes?
I dont mind widening the fenders if necessary, but I would like to avoid it if possible.
maz89
Contact Trevor (lockone) at Tenn. Wheel and Tire for a set of TowNasty's, that should take care of your problem..
low95xlt
i think even with ownastys you still ahve to widen a lil
rnonelower
do you have the # for tenn wheel and tire also if you use the townasty set up can u put air bags on and not relocate the gas tank
okcderek
If you run these they will tuck...
W
watahyahknow
townasties are a lot narrower but last i heared was that trevor had a hard time finding them new (seems alcoa doesnt make them no more?)
another thing you could try is get a chassis cab axle , these have a narrower trackwith
