Dually Suspension \  3800 front bag buckets
Dually Suspension Dually Tech
views 1329
replies 9
following 7
rnonelower   +1y
does anyone know anything about the aim industries front bag buckets to fit 3800 bags up front I have heard that it is hard to lift a big block up with a 26 or 2500 bags I dont want to run 150 psi to keep my truck off the ground and I meed good lift as I have to pull campers up to 10,000 pds
okcderek   +1y
I run Slam 7" bags in the front and its plenty. My suspension locks up or maxes out at like 165-170 or so. My ride height is at about 110- 100psi. I have never heard of someone using a 3800 in the front of their dually.
...and AIM is not someone I would order from. Try Suicide Doors for bag brackets/cups. Thats who I ordered mine from.
okcderek   +1y
Here is what I ran in the front in a 7" bag...
and these are my rear in an 8"...
If you are concerned about quality...I wouldnt mess w/ AIM.(my personal opinion)
rnonelower   +1y
what about 2600 firestones in the front and rear I already have 4 that I was going to use on my mazda would those work instead of the slam bags
burntup   +1y
my truck had 2600's on it and I had no problems
skidrow   +1y
mine hase 2600 it works fine
baggeddogs   +1y
[quote="rnonelower"]does anyone know anything about the aim industries front bag buckets to fit 3800 bags up front
You dont need them, I just did a dually last weekend and put in the 3800lb bags up front. It is easy to make it work with out buying anything. ....
barely legal welding   +1y
i am running 2600 firestone and have no problems eather square body and big block.
Richie
rnonelower   +1y
could u post some pics of the 3800 install so i would be able to see how to do it
monzter kuztomz   +1y
I had 2500s in the front of mi 1/2 ton 94 Chevy & they sucked, I was only running 160 PSI though too. I then put 2600s in with a 200 PSI pressure switch & it was much better & a lot faster. So I'd go with as big of a bag as you can. When I bag my 93 Dually I'm gonna do what ever it takes to fit HE8s up front, yeah I'm gonna dual port it.
