Dually Suspension \  16" tires...?
16" tires...?
Dually Suspension Dually Tech
views 1194
replies 9
following 7
okcderek   +1y
Question for those running low profile tires on there trucks. What psi are you running? I have tires on the front of my dually and they are at the max psi per the sidewall specs....but they look low. I realize its cause the tires are not for a 1 ton, but I know guys are running them anyways. I just want to know what psi some of you that are running them are running.
onefasthoagie   +1y
i put like 70 lbs in mine. i think max was like 80. not sure though.
tuckin22   +1y
you have probably said somewhere but what size tire you running?
rhmdually   +1y
im running the max it says on the side wall, but i will agree they look alittle low
jcampbell1180   +1y
^^^X's 2^^^
onelow1ton   +1y
max and still look low
onefasthoagie   +1y
i finely got outside today
225 70 16 i think.
tuckin22   +1y
i figuered it was i little smaller than mine im running a 225/75r16
not by much though what is the load rating on your?
nvr2lo_hb   +1y
Depending on ur load rating like stated above changes ur max light truck tires have load ranges of C,D,E however if u are running a P225/75r16 I wouldn't recommend running over the max which is prolly about 45psi, the only way to get around this is lookin at companies like TOYO they have a little lower profile 16" tire. That would work but they are usually more aggressive like an all-terrain, for the most part if u aren't doing heavy towing those passenger or lower rated tires will work if ran at max but wouldn't exceed, cuz as u drive (especially highway/interstate) tire heat up causing ur 45psi to go upwards of like 60psi and MAY(not saying it will) cause tire failure. I used to be a tire salesman, so I can answer sum tire questions.
nvr2lo_hb   +1y
Depending on ur load rating like stated above changes ur max light truck tires have load ranges of C,D,E however if u are running a P225/75r16 I wouldn't recommend running over the max which is prolly about 45psi, the only way to get around this is lookin at companies like TOYO they have a little lower profile 16" tire. That would work but they are usually more aggressive like an all-terrain, for the most part if u aren't doing heavy towing those passenger or lower rated tires will work if ran at max but wouldn't exceed, cuz as u drive ,especially highway/interstate, tire heat up causing ur 45psi to go upwards of like 60psi and MAY, not saying it will, cause tire failure. I used to be a tire salesman, so I can answer sum tire questions.
