Uneven drop...94 CCD
L1
low 1 ton
Just installed a 5/7 DJM drop on my 94 CCD today. I wish it were bags, but my girl bought me the drop kit, so I can't complain. I measured at the fender lips and noticed the passenger side is about 1" lower. Is this common? Everything is installed correctly. I forgot to measure before I dropped it, so I don't know if it was like that. Not really a big deal, cuz hopefully I will be bagging it before long. Any ideas?
brianbgboy's avatar
brianbgboy
sounds like you have the good ol' chevy gangsta lean problem. most chevy trucks have it.... later, brian
L1
low 1 ton
Thats what I figured. Oh well, guess I will have to live with it until I can bag it.
dragnasty's avatar
dragnasty
Mine sits the same way.
low95xlt
yea i hear they are a common problem i would say stick it out til bags and then it will be a okay
onefasthoagie
this might not help, but when i bagged my truck i noticed the sway bar end bolts wern't the same length. i don't know if it was a ho-chi guy that had it before me. but i put even length ones on it. also could the spring be seated correctly in the pocket? i think it has a grove for the end of the spring. donno if that would make a difference?
klez's avatar
klez
I had the same problem last week when I lowered mine. It turned out the spring had fallen out of the upper pocket/fingers and was sitting uneven. I pulled the spring and could see where the fingers had pushed the paint off, so I reinstalled it and the truck sits level now.
L1
low 1 ton
Yea I am pretty sure the springs are seated correctly. Plus its so little of a difference it's hardly worth pulling the suspension apart. I'll stick it out til I can bag it.
liljlowrider's avatar
liljlowrider
if its minor its probably just the chevy "gangster lean" almost all of them do it...
jcampbell1180's avatar
jcampbell1180
Yup...def gangsta lean.
