Axle hitting frame
Axle hitting frame
L1
low 1 ton
Just did a 5/7 drop on my 94CCD and the axle hits the bumpstops on the bolt in c-notch. Its annoying, and probably cant be eliminated unless I get helper bags, but I was looking and was wondering if anyone has removed the bumpstop pad on the axle itself? I may bust out a grinder and grind it off to gain another 1" or so. Just curious to see if anyone has done it and the results....
liljlowrider's avatar
liljlowrider
grind those babys off
low95xlt
shave them off
low1ton's avatar
low1ton
cut the bumpstops down! I had to do that on my s-10 no big deal.
jcampbell1180's avatar
jcampbell1180
I'm not running any on mine.
erock805's avatar
erock805
Shenanigans...!!!!
you need custom ones!
joking of course...dont have any on mine.
huskerdually
Will it still hit with the bump stop cut out. If it will just hit once and a while and not to hard then ditch the bump stop, but if you gonna be smakin it like a pimp to a ho then I would fix with a bigger notch.
jcampbell1180
^^^Dork^^^
