Dually Suspension \  a.r.t. setup ?
a.r.t. setup ?
Dually Suspension Dually Tech
views 1457
replies 12
following 8
badhabits   +1y
i have a 97 chevy 3500 crewcab and im curious if anyone with a similar truck has ever used the airride technologies bolt on kit for it. any pros/cons? how low did it actually get? how much articulation did it have? how good was the ride compared to a regular non-bolt on setup? any and all imformation is appreciated.
krewzlo   +1y
I have one on my dually. I like it alot, with using a standard belltech notch which is what art designed it for it was comparable to a 5/7 static drop at ride height. It will not lay out without going to a bigger notch. I originally bought the belltech notch to go with it as my truck had like 5000 miles on it when I did it and wasn't looking for it to lay frame at the time. It got good enough lift to get around just fine and towed great. When I did go lower I built my own bigger notch and had to move the bags for it to work. I went with triple stacks behind the axle which give huge lift and ride great and even better with a trailer behind it. I had to relocate the panhard bar to go lower as well. I have pics of it in my garage on here I believe.
For the money though you can buy just a universal hd four link and save a bunch of $$ I would not buy it again but at the time, 8 years ago, not alot of companies were making good kits back then so I went to art. I wanted a bolt on kit at the time so it was the way to go. Hit me up if you need anything else about it, it may take me a day or 2 to get back as I am working a ton right now though.
badhabits   +1y
what other company would u suggest that i buy my four link from? i want to be able to get the truck to lay out but still have it stout enough to tow with. the a.r.t. kits are alot more than i really wanted to pay but ive always heard they were good and strong and the fact it was bolt on was also a plus. however, any kit suggested does not have to be bolt on.
and another question........has anyone ever used the c-arms from chassistech? are they any good? i have looked at them the last couple days and the prices seem pretty reasonable and the pics look pretty good. the only concern i have is i can get upper and lower arms from them for about 1/2 the price of the lowers from a.r.t.
huskerdually   +1y
I had a set of lower control arms on my 88 burb. Not quite the same thing, but I wasn't very impressed with the build quality and design, just didn't seem quality, no real glaring flaws, just looked cheap.
krewzlo   +1y
As far as 4 link suicide doors will make bars whatever length you need them and I believe they will make them extra beefy if you want, just tell them what you want and they will you hook you up.
I would stay away from chassis tech, there is a reason they are cheaper, they are cheaply made. I had a set of uppers on my s10 back in the day and they were covered in welding splatter and the balljoint angles were terrible, blew out the boots in a few days. Everything I have ever gotten from them never fit quite right and just didn't have the quality that you should expect.
okcderek   +1y
Suicide Doors...........and when you order tell them you want the bigger bars cause its going on a 1 ton. Only problem I have had was w/ an axel tab and they fixed that problem by making the thicker.
dropd80s   +1y
Derek do you have pics of your set up?
kblr elf   +1y
ssd good guys they dont bullshit u like airbagit joe an chris can kiss my ass i wouldent buy shit from them but thats just me
badhabits   +1y
after looking at the suicide doors site and talking to rickie there i think i am going to run one of their parallel 4 links with bags on the axle. im having problems now deciding what size bags to use. i realize that by putting bags on the rear end i will only get as much lift as the bag offers compared to getting more lift if i put them on the bars but i think this will be alot stronger for towing. this being said, i want to put the biggest bags i can on it. i found some f9000 after a google search but im pretty sure there has got to be bigger ones available. does anyone know what size bags are on semis? can i use them? also, should i do a panhard or max link? if i dont use the chassistech arms what is the best way to lay out the front? i realize i have alot of questions but this is my first airride setup on a dually and would prefer to do it right the first time. any and all suggestions will be greatly appreciated!
slammedxonair   +1y
If your interested I build custom 4 links to specs. I am also a site sponsor here. Let me know if I can help you out.
