carrier bearing question
poopskidz
I have an 86 crew its bagged and i was wondering if people are raising their carrier bearings, or if it really matters my pinion angle is pretty good at full lift but i get noise back there when riding lower and i was thinking if i raise my carrier bearing the short shaft to the rear end wouldnt be at such a steep angle. Just a thought. if anyone has any pics that would be great
sittinlow88
I made a whole new crossmember where my carrier was and raised it 2 1/2" But mine is an 03'
someotherguy's avatar
someotherguy
Here I go speaking out of turn again since none of my duallys are lowered, but I do know any time you take an ext cab lower than 4" static out back, you're supposed to raise the carrier bearing and transmission mount. (obviously doesn't apply to anything shorter than an ext cab since 1 piece shaft) Just a flip kit on a 2500 is 8" so I've got that and the spacer kit installed. Can't remember if I've got the pinion angle shims in there or not, shit was done over a year ago now.
Richard
bagdduallyon24z
I raised the carrier bearing on my 00' Crew Cab up 2" and everything works fine.
skidrow
i just got mine driveable this weekend and was thinking the same thing that i need to rase it up im going to put it on the lift at work and see what it looks like i get a wird vibration at about 50 coming from the back
i would love to see a pic of square at ride hight to see what peaple have done.
erik
pig rig's avatar
pig rig
look at ben shadys build thread I think there is pictures in there
