Dually Suspension \  4 link bar length ???
Dually Suspension Dually Tech
views 1481
replies 4
sparkys-crewcab   +1y
i found a heavy duty universal 4 link that has 1 1/4 inch round, 21 inch equal length bars, poly bushings...etc.. it comes with the new frame mounts , so i wont be able to use the stock leaf hangers...
will this kit be good to use? or do i need longer bars?
i was thinking about a 2 link , but they cost about what a 4 link kit does....
huskerdually   +1y
There is no reason it won't work. How much lift do you want to get? With the shorter bars you will get more fore/aft movement through the lift range, but that isn't really a terribly big deal.
bdydrppup   +1y
are you runnin bag over axle? for bag over axle i prefer real short bars for strenght but if your goin bag on bar then you will want longer because of travel your pinon angle and wheel base will change alot with short bars.
huskerdually   +1y
If set up right pinion angle should not change at all.
sparkys-crewcab   +1y
i dont need alot of lift...i want to have my ride height a few inches off the ground. with just enough lift to get over speedbumps.....
i have a motorhome rear end, so my bags are going on the inside of the frame, over the rear end, i need all the room i can get..
im going to go ahead and buy the 4 link kit.....thanks guys
