Dually Suspension \  Lowest kit made for the 4wd Duramax??
Dually Suspension Dually Tech
views 948
replies 2
35hundy   +1y
Looking to lower my other truck....its a 2008 Duramax 3500 SRW. Its a 4 x 4...I see DJM makes a 3"/5" drop kit....which would be ok, just wanted to make sure no one has anything else out there before I pull the trigger.
Thanks!
hangslo   +1y
I have a 3/5 kit for an 03 HD that I removed before selling the truck ... mine was also a 4 wheel drive. DJM told me that the control arms would not work, and they were right, but all I had to do was move the lower shock mounting tab to clear the front shafts and it worked fine. They also told me that the kit would cause the CV's to bind ... also BS ... everything worked fine.
I had mine set up at a 5/7 drop by turning out the torsion bars and removing a couple of rear leaves. Removing the rear leaves made it ride so much better, and if you have air assist bags, then load capacity is not a problem.
I have the complete kit with shocks still new in the box. I ordered it from Godfathers and it took them three months to finally get the right shocks to me, so in that time I had already removed the kit to trade the truck in on a Trailblazer SS.
If your interested in the kit, let me know.
sway05max   +1y
pm sent ^^^
