Dually Suspension \  srw axle swap
srw axle swap
Dually Suspension Dually Tech
views 908
replies 2
low 1 ton   +1y
i can pick up a 1 ton srw axle. but it has 3.73 gears, and from what ive researched i would need to run bigger inner wheels. i am going to putting 22's on with 16" inners and laying it out. is it possible to strip the axle down to nothing and put my dually stuff in it for a shorter rear end so i dont have to stretch the fenders? the srw axle is 67.5". is that too short or what?? and also are the 3.73 gears better than 4.10?
wide load c-30   +1y
I went from 4.10's to 3.73's when installing the C&C rear in my truck for lower revs on the high way.
lockone   +1y
What year truck are you working on? What year SRW truck did the axle come out of?
Dually 16s will not fit on the SRW drums and I dont know if the drums will interchange. Also the measurement you gave for the SRW axle is longer than most factory dually axles.
