Dually Suspension \  wheelbase measurement
Dually Suspension Dually Tech
views 936
replies 7
chumpchange   +1y
i need a wheelbase measurement for a shitbox crew cab. i got in a rush cut everything off and forgot to measure. does anyone know what theres is or can anyone measure at ride height from first body mount in front of the rear end to center of axle? should be thirty something i just wanna make sure im rite with what i think it is. also i had my wheels centered layed out before. thanks guys
someotherguy   +1y
Wheelbase is 168.5" on shitbox crew longbed.
I can't get you the measurement you're looking for because my truck is seriously hack-modified (wrecker unit, etc.)
Richard
chumpchange   +1y
thanks man is that measured from center of front wheel to center of rear?i
lockone   +1y
I can get the body mount measurement if/when it stops raining outside.
someotherguy   +1y
Most likely. That's the factory advertised wheelbase, which you'll also find at the top of the SPID label of any of these trucks, that is, if the label isn't wiped out already.
Richard
chumpchange   +1y
i app it guys i was rushing like an idiot in the dark last night and completely forgot. lock i alawys measured mine from the the back of the closest mount to the rear end center its 31 something i think at ride height cause i always center them layed out but it was two linked before. i sold my house and am moving so i wanted to put the parallel and watts on before i lose my place to weld. thanks again
lockone   +1y
From the back of the closest body mount (mount that has both bed mount and body mount on it) I measured 48" exactly. I also measured from the center of the front leafspring eyehole and it measured 35" to the center fo the axle.
chumpchange   +1y
thanks guys i app it i will post up pics this weekend as i start putting everything on it
