Dually Suspension \  2000CCD
2000CCD
Dually Suspension Dually Tech
views 921
replies 3
kreatve1   +1y
Hello all new to the Dually Scene Board.... Love My dually!!!
Here's my dilema:
I have a lowered CCD reently got new tires to the size of 225/60/16 and I would like to change the gears in the back to better match how it was at stock. Stock gears are a 4.10 ratio. Any ideas on what I should change it too. Also thinkin about adding a locker since I'm down and have it torn apart.
1967rs   +1y
some where in the 350-340 range.
liljlowrider   +1y
personally i would go with 370's range this way you dont lose to much lower end torque but improve highway still.
hangslo   +1y
Ditto ... if youre planning on doing a lot of towing and that is most important to you, then there is no need to change, cause you will be able to tow a house with that tire and a 4.10 gear. If you are looking to not lose too much mileage but still have the best of both worlds, go with 3.73's. The next gear for a 14 bolt is a 3.42 and that is what you would want to use for highway mileage.
