Bags vs Springs
gjfent@gmail.com's avatar
Bags vs Springs
gjf's avatar
gjf
Ok here is the q's for you that have done both.
Is there any real big difference other than the adjustable ride height, in ride quality between air bags vs spring?
milkshake's avatar
milkshake
depends on how still your spring is and if you run shocks on the bag setup
i personally love bags with shocks cause every vehicle ive built just floats down the road and just the suspension upsoarbs the bumps and stuff easier to me personally but to each his own
gjf's avatar
gjf
Thanks Milkshake,
Is it a big difference between the bags and the springs? Like a comparison of the stock springs to your ride. I will not lay my truck out but it will be lowered with a little tuck. Also do you have to pump the tank up every morning to air up the ride height or does the system hold pressure? Also when you have the truck in the lowest position does the weight of the truck rest of the deflated bag or do you but bump stops to protect the bag?
milkshake's avatar
milkshake
the way the system works is there is a tank and a compressor and the compressors builds pressure in the tank and then when you have enough u do what you do but you gotta seal up all your fittings all of em or otherwise you will have leaks i dont have any leaks what so ever in mine and my tank holds pressure pretty well id just run the compressor on my way home the night before and im fine next day and about the bump stop thing i think its a personal choice but if you go with slam bags they have internal bump stops in them to keep from getting damaged
