Dually Suspension \  lay frame with 5th wheel hitch?
Dually Suspension Dually Tech
views 2459
replies 7
following 5
nosrex   +1y
I am rolling a 94 2500 converted dually with full 8 bolt conversion. I am wondering if anyone knows what i would have to do to lay frame and maintain my ability to have a 5thwheel hitch. If anyone is running a setup like this i would love to see pics...
thanks
Shawn
guilty by design   +1y
Are you talking an actual 5th wheel or gooseneck? Either way you can save a lil room by mounting the pin slightly foward of the axle centerline (3-6'') Its actually better to do this since it distributes weight to the front, i dont know why more people dont do it when they build their crossmembers.
nosrex   +1y
i am talking actual 5th wheel, i see alot of gooseneck setups. I have yet to find a true 5th wheel bagged rear picture
sick82   +1y
a 5th wheel take a much larger plate then a gooseneck. all you will have to do is setup around you notch higher then the pumpkin when layed out. it would be simple and very ver possible. i have a b&w turn over ball on mine and can drop in the 5th wheel attatchment if i hade it.
josh
nosrex   +1y
so set the whole hitch higher is what you are saying
sick82   +1y
yea, a tad higher then the pumpkin.
josh
severedtiesdually   +1y
just build the mounts for the hitch on top of the bridge run a 4link with panhard and put big sleave bags behind the axle. rides great will & haul anything. I have 16,000 lbs of load capasity on the rear of mine. I a 48' inclosed a 50' wedge and have hauled skid loaders and excavaters that weigh in at 10,000 lbs or more.
thekandyshop   +1y
SeveredTiesDually
IS YOUR TRUCK BAGGED IS IT POSSIBLE TO GET LOW AND KEEP ALL ALL SPRINGS IN REAR
