Dually Suspension \  which rear end for 6 22's?
Dually Suspension Dually Tech
views 1911
replies 4
joebob   +1y
my buddy just got 6 22's and of course they poke out but im wondering if we find a c & c rear end will the 22's hit the leaf spring and is there a better rear end to get that will work with 4 22's out back and keep the leaf springs?
wide load c-30   +1y
You don't specify what kind of truck it is, but I think it's the same for all dually's. The only way to run 6 22's and leaf springs is with the stock rear, you have to widen your fenders if you want to keep the leaf springs. Or stock fenders with a narrower rear and a 4-link to run 6 semi's. I'm running a C&C with stock fenders, stock leaf springs, but 4 semi's and teenagers on the inside. I wanted to move the leaves to the inside of the frame so I could run 4 24's but the pumpkin on the FF 14 bolt didn't allow that.
joebob   +1y
its an 89 square body...what do you mean by teenagers? do you think they will tuck with stock rear and only two 22's out back
wide load c-30   +1y
Teenagers = 16's.
No they will not tuck with the stock rear and 2 22's.
hooligan   +1y
I have a 85 reg cab I've been looking around here on duallyscene trying to figure out if a c&c axle would work with 4 24s in the ass end and so far it seems like it would be a tight fit ,I have been looking at different axle combos and thought about going with a srw and shave down the face of the wheels. Has anyone done this successfully?I guess if it comes down to it I cab narrow the frame rails for the c&c axle
