Dually Suspension \  Bagging a 90's burb?
Dually Suspension Dually Tech
views 1008
replies 2
following 2
huskerdually   +1y
Okay I may end up with a sh!+b*x suburban, I would say mid to late 90's(it's got brake problems hoping to pick up real cheap). What all does it take to lay one flat frame? Nothing to serious in the wheel department 20's maybe 22's if it aint to hard to steer with such a large tire. Probably 4 or 3 link in the rear.
orangelowmazdawg   +1y
had a 93 burb bagged on 22's w/265-35-22. up front had dropped spindles, front cups from extensive metal works, notched lower control arm mounts, notched upper arms, notched frame for tie rod clearance, raised fuse block( up and to the brake booster), remove hood hinge springs for tire clearance when layed out, clearanced spring pocket for bag. rear had a 2 link with bags on bars, and an 8" notch. layed front to back, front crossmember in front and gas tank in rear. hope this helps husk. later Brad
huskerdually   +1y
Thanks don't sound to bad.
