frame clearance with c&c on a 95
I
impala_631
Running 4 22s on the rear of my 95chevy,was wanting to link, notch and swap a c&c rearend in,will the frame need to be shortened to clear the inner wheels?
lockone's avatar
lockone
The frame will need to be narrowed if you are going to install the C&C rearend and the inner 22s. You will also have to move your link system inside the frame rails for clearance on the wheels.
I
impala_631
How many inches does it need narrowed?my inners are 5"away from the frame now,I was thinking the c&c was 4"shorter per side
lockone's avatar
lockone
The amount you narrow the axle all depends on the width of the axle that you start with. The narrowest C&C rear axle is 44" plate to plate and is 8" narrower than most stock axles.
Only 1" clearance is not a lot to allow for articulation of the wheels from left to right. I know every truck we have done the frame rails have been moved inwards for clearance.
