Dually Suspension \  negative camber.
negative camber.
Dually Suspension Dually Tech
views 1354
replies 3
jeffs_tonka-toy   +1y
Ive been through both front tires already, and i found out i have some negative camber on the front.
Could this be from the drop? can i just adjust it with some shims or do i need longer a-arms?
Jeff.
wide load c-30   +1y
Did you align it after the drop?
lockone   +1y
Check alignment and also check tie rod ends and ball joints.
jeffs_tonka-toy   +1y
I got it already dropped, the bushings looked roached, im going to replace them before i buy a new set of tires.
