74 drw in 00 c3500 srw
E
mintcrew
hey guys.... has anyone took a square body drw axle and put it in 88-00 body style 1 ton? if so.... how did it go? thanx..
lockone's avatar
lockone
Done it several times. It all depends on which width axle you get. My '94 model had a C&C rear axle in it that was 36" plate to plate. With this axle you have to basically build a new back half to accommodate the axle.
There are some others that you can get by with just moving the spring perches and some minor trimming on the frame.
mintcrew
thanx for the info..
comegetsome's avatar
comegetsome
i see your in GA...i have one of those axles layin out here under my shelter i removed from my dually last year when i bodydropped it...has 4.10 gears ill sell it cheap if you dont already have one
