New here...4wd airbags?
X
X
xraypipeliner
I am looking at putting airbags on my 2003 F350 DRW but all the pics i see are 2wd trucks. I also pull a fifth wheel that weighs about 13,000#. Just wondering if i can bag this truck and still pull fifth wheel.
h2omelon(nick)'s avatar
h2omelon(nick)
Welcome to the site. Yes you can still tow with airbags.
X
xraypipeliner
Can someone point me in the right direction to where and what i need to buy?
lockone's avatar
lockone
Are you just wanting to install a helper air ride kit or are you wanting to bag all 4 corners?
X
xraypipeliner
I want to do all 4 corners. It will have 285/40-24 size tires and i need to still pull a fifth wheel all over the country for work.
lockone's avatar
lockone
I assume you have a straight axle in the front with leaf springs. Basically all you can do is just install a set of bags over the axle in the front and rear to get the upward lift you are needing. As far a bagging the truck to make it a bit lower you will need to get rid of the leaf springs for a link system or build some lowering shackles for them (will only lower the truck around 2").
