Dually Suspension \  I need some control arm help after bagging.
Dually Suspension Dually Tech
views 1492
replies 5
cochino12   +1y
Just installed arilift 2600's using factory control arms in my 88" squarebody. I was hoping I would get much lower than it is, the control arms are still about 3" from the ground and the bag is completely compressed. I know porterbuilt makes some upper/lower arms but I dont have the $$ for them right now. Since I am cheap is my only option cupping my stock arms and shorter tires (225-75-16 now)?
big bear   +1y
cupping your arms will help, your other option which MOST squares require is to 'z' the front. then after that, make sure you clear on your inner fenders and theres no binding ect on the balljoints.
comegetsome   +1y
do you have drop spindles?
cochino12   +1y
Yes, 3".
big bear   +1y
you know you dont have to have drop spindles to lay out tho.
bk2life   +1y
i have 215-85-16's no drop spindles, cupped my lower arms, pie cut the uppers, z'd frame and lays out.
for lifting info i am body dropped, tuck almost half wheel, and lift about 2 inches above tire at full lift.
