Dually Suspension \  where to mount air helper kit?
Dually Suspension Dually Tech
views 2102
replies 11
following 5
progrudge   +1y
I bought a ride right kit for my 2000 Chevy c3500 with a flip kit on rear where do you mount it ? In c notch? Any pics or help would be greatly appreciated!! Thanks ahead of time!
progrudge   +1y
No one? Come on guys I know someone has some insight on this subject if everyone is using an air helper.. do I need to modify brackets with kit or does it go right on? Do I cut big block off top of rear end where snubber is? Thanks
bigcat   +1y
I had to modify my bracket a lot to get them on. I have the bags mounted to the spring, but cant remember if they are in front or behind the axle. I will check tomorrow, and see if I can get some pics.
calfboy   +1y
mine were on the springs as well, they were behind the axle.
progrudge   +1y
OK thank u!!!! Pics would be wonderful
krewzlo   +1y
Are you using a belltech notch? The kit i had years ago mounted behind the axle. The top bracket bolted on the back 4 c notch bolts. The bottom had u bolts that held the bracket around the spring. Have you checked the manufacturers website for instructions?
calfboy   +1y
krewzlo's right, my kit was bell tech, mounted up just like he said. I don't have pics, I took them off, n the process of bagging.
progrudge   +1y
Djm flip kit... the instructions show bolt on top of rear axle and under frame. That's why I was asking... I asked lockone about which kit he said either one so I got the Firestone thinking it would be a good brand kit. Just doesn't make sense for a lowered truck
krewzlo   +1y
I dont think that kit will work on a lowered truck, from the sounds of what you describe, it is only for stock height trucks. I will search for a pic for you
krewzlo   +1y
Is that kit part number 2025? If so, it wont work. This is what you need, or a kit similar.
