Hey guys i wondering if anyone on here knows of a company that sells a front brake conversion for my 94 c3500 id like to convert mine to a 2pc rotor seperate the rotor from the dually extender cause i am sick of buying new rotors @ 150 dollars each and they dont fit on my brake lathe. so if anyone knows any companys or ways to convert it plz HELP ME OUT lol
mobboss
hell i dont know if i have ever seen that! even my dads 72 rocket launcher had one piece. good luck tho. maybe try to make them yourself?
krewzlo
If you go with semi wheels, you can convert your rotors over to 3/4 or 1 ton fleetside ones but you need to extend your control arms 2.5-3". I am not sure if it will work with 16's or 19's or even direct bolt on 22 or 24's if you happened to come across a set. Michigan Metal Works makes extended control arms specifically for this, but are pricey, but bad ass as well. I will be ordering a set when I can afford them.
krewzlo
Some dodges and ford also have used a 2 piece extension and rotor, but unsure if the bolt patterns and length would be correct. You can find them on ebay. Newer chevy's also used them but I believe they are a different pattern.
I spoke with trevor about building a set that had the 10 bolt adapter built in and said the cost would be very expensive just do to the size of blank he would need to machine them out of.
someotherguy
I've seen the 2 piecers on Chevy's, but it's been so long I can't remember exactly which ones. Pretty sure it's going to come down to not only year model but also which supplier provided that particular set of rotors. They're out there, but how easily available, no idea. Sorry
