york vs. viair
york vs. viair
bigbeardedbastard
i have searched and read as much as i could. i am looking at ditching the viairs i have currently and going with a york 210 edc......for those of you currently running yorks are there any downfalls vs running electric compressors? my viairs are slow to fill my tanks and without a high output alt...they drain the crap out of my battery. looking for thought and feedback from you all
thanks
BBB
krewzlo's avatar
krewzlo
I run one and wouldnt run anything else. The only downfall is having to fill with oil frequently. Not a big deal though. I keep melting the hose from the comp to the tank as the air comes out hot as hell. I have been running hydraulic hose but that goes after awhile too. I am switching over to thick wall flexible copper very soon.not sure how that will do but worth a try. Mine runs all the time as i am lifting and dropping frquently when cruising. On the highway it fills my 10+ gal in about 15 seconds from 100-200psi. I run a small electric just for back up too. I will eventually run 2 yorks when i get time to build a bracket for the 2nd one just because i am switch happy some days.
andy@alldayfab
There is no down side. Worse case is the compressor completely fails and you go spend $50 dollars on another one. Electric compressors work well on cars and small trucks only because its very difficult to mount an EDC on them. Im running a york 210 on my 454 97 chevy and the only issue Ive had is the clutch went bad and I had to spend $25 dollars on a new one.
bigbeardedbastard
awesome! these are the answers i was lookin for! although i am not all that switch happy, florida roads suck and i would like to know that i have the air handy when i need it!
comegetsome's avatar
comegetsome
Yea man definitely run the York....but keep those Viairs under there in case you have something go wrong with your York they will get you home
bigbeardedbastard
thats kinda what i was thinking....ive got one strong viair...the other runs rough. but still good enough for a backup.
severeddime
I'll run a York if I can figure out where to mount it on the 6.5
I ran one on my S10 and I don't think I could go back to electric and keep my sanity.
bigbeardedbastard
well for now i am putting in a new 383 stroker motor with a v-belt set up....i should have plenty of room for the york to mount.....i have a industrial edc on my work truck i use to power a jackhammer and was always impressed with the airflow.....the viairs have never impressed me.
comegetsome
My boy Dillon has a small block in his dually with a V-belt setup....I'll see if I can get a pic for ya of how he mounted his
bigbeardedbastard
that would be awesome!! thanks! hows your build coming btw? havent seen anything new recently??
