Gas tanks on C30
noclrnce@yahoo.com's avatar
Gas tanks on C30
noclrnce's avatar
noclrnce
Those of you who have body dropped a c30 crew dually did you have to modify how the gas tanks mount or do they stay where they are? Pics if you got them.
short1
I had to move mine because of the parallel 4 link. I'm sure it depends on how you b drop it. Mine is traditionaly dropped but my tank is in the bed. I don't know if that helped you or not.
laidout84
I asked another member the same question. He told me he moved his up and didn't have to modify anything, it still cleared the cab.
bigcow94's avatar
bigcow94
I'm not body dropped but I went with a gas tank out of a suburban. I believe it was a 31 gallon tank. fits right in between the frame rails and you can use the factory suburban straps if you want to add a couple chunks of tubing.
john-e bravada's avatar
john-e bravada
With a 4" body drop my factory tank hung down too far so I made a custom one to go in it's place. The suburban tank I had didn't fit either. It was too tall with the stock rear bed floor. Cut the floor out and you'd have plenty of room.
