FENDER FLARE QUESTION
jack@sullivanscabinets.com's avatar
low1ton's avatar
low1ton
Anybody know if they ever made a fender flare to fit the back dually fenders that will match with the factory front flare on 88-98 trucks? any help please
huskerdually
I don't think they did.
low1ton's avatar
low1ton
Does anyone know if a factory rear flare from a fleetside will work on a dually fender? I have seen a few duallys with them on the back but not very often.
skidrow
im cunfused do u meen stepside?
low1ton's avatar
low1ton
no I mean just a standard bed not stepside.
huskerdually
I don't see why not, but I don't know for sure.
someotherguy's avatar
someotherguy
I think the wheel opening is different enough between a single wheel fleetside and a dually that there's no way the factory flare would work, unless you did some heavy modifying. Not trying to discourage you but it seems like if you gotta modify the flare and fender maybe it would have been better to just stretch the fender instead, probably not easier but the end result would look better and be stronger.
You might find a 4x4 in a boneyard that has some you can score cheap and try, or LMC sells them new (chinese garbage) for like $100/ea.
Richard
guilty by design's avatar
guilty by design
I have a set of rear flares im making fit my dually. Theyre just a hair taller than a dually wheel opening so cutting them is a must.
dually502
I have found some on the net but the flares cost as much as the dually fender.. If you are gonna go with a flare that you have to modify and modify the fender, then why not just mold one on.. I have seen two done this way.
huskerdually
I stand corrected.
Related Discussions in Dually Exterior
