so im going to keep my stock 16 inch wheels i have a 85 gmc what size tire do i need to lay fraim??? thanks for the help
low4life
come on guys help me out
skeletoncrew
Have patience. Wait for Lockone to see your plea.... he'll set you straight.
WL
wide load c-30
It all depends on the setup. It could be a 225/75-16, it could be a 235/85-16, etc.
low4life
what do u mean??? it is bag over axle 235/75/16 out back and 245/85/16 in front at this time need smaller
WL
wide load c-30
What I mean is it depends on the size of the notch, whether it has spindles, etc. That info is needed in order for you to get your answer.
lockone
225/75/16 is the common tire size used on 3500 trucks nowadays. However in your case a 235/85/16 would have been the stock tire size.
If you want to lay frame, I would go with a 225/75/16 and do the necessary trimming. This way down the road if you want to upgrade wheel sizes you can go with the same height tire.
