Hi fender help.
Hi fender help.
JE
jason eden
Hi I bought a 96 and someone looks to have cut the rear fenders from front to back the raised about 1" in the center I have pics but not sure how to post them but I was wanting to know is it necessary to do this to tuck 22" rims. Because I cleaned them up a bit but they kinda look like hell Thanks a lot for any help
krewzlo's avatar
krewzlo
What size drop is on it? To lay out on 22's they may of had to raise them to clear, if it is body dropped then definetely the will need to be raised. I am assuming its a gm dually? You also need to widen the fenders or have a narrower axle in it to tuck them.
JE
jason eden
96 chevy dually it's bagged on 16's with pretty big tires I want to run 20's If they raised the fender outside edge 1" will they clear ? Thanks
krewzlo's avatar
krewzlo
Not sure on the 20's. From what I have heard they will need to be widened though.
lowtaco114's avatar
lowtaco114
Bagged on 22s dont need to be raised but need to be widened a few inches. (2-3inches possibly more) unless you can shorthen the axle or run a cab&chassis rear end.
Dont know much about the 20s but I would assume they will need to be widened
Related Discussions in Dually Exterior
