I've got issues...
jasoncampbell1180@gmail.com's avatar
I've got issues...
jcampbell1180's avatar
jcampbell1180
Alright, this is an SOS call to all my Squarebody Brethren...
I've developed a problem lately and I'm not sure where it stems from or when exactly it started. When I turn on my lights, my dash lights don't come on, my gas gauge stops working (needle drops to 'e'), and my high beam indicator turns on for low beams/goes off when I hit the high beams.
Any ideas? It's driving me nuts. I tore the dash apart this weekend, but to no avail.
Eric?
huskerdually
Sounds kinda like a bad ground somewhere.
jcampbell1180
Yeah, I checked everything like that, but it's worth another look.
huskerdually
I figured you did. Try changing out your light switch those do go bad a lot.
jcampbell1180
Yeah, that's kinda what I was thinking.
dropd80s's avatar
dropd80s
There is a ground junction on the drivers side kick panel just up under the dash, I would pull all the terminals and make sure their nice and clean. Also the head lights should be grounded left and right on the core support just above the head lights or one on each fender, but that all depends on how molested your square is....
W
watahyahknow
lightswitch seems to be a common problem the full power to the headlights go through it and the kindah skimpy wiring, there are kits available that put a relay between the switch and the lights and let those take power directly from the alternator/battery through thicker wiring .
its a good idea to do that kit the lights burn brighter and theres less hazart of the lightswitch or the wiring to the lights catching fire
jcampbell1180
I'm kinda wondering if it might have something to do with the printed circut on the back of the cluster.
skidrow
change the light switch out brother.
all so if that not the prob the hi low light switch
pig rig's avatar
pig rig
yea go with a new light switch but the only thing that puzzles me is the gas gauge part of it. if I had a wire diagram to look at I wouldn't be so confused
Related Discussions in Dually Audio/Interior
