Dually Projects \  The Project
The Project
Dually Projects
views 1357
replies 2
following 2
99350   +1y
Ok so this is going to be a fairly slow build doing things as budget allows. Also I may be slow on pics gotta borrow my folks camera and get their help with posting pic (computer illeterate here)
I have a 99 F350 CC Dually 2wd 7.3l diesel
The Plan:
Steering, Suspension. Brakes, Wheels, and Frame:
SSBC F brake kit
SSBC calipers for front w/ custom bracket for R
Cryo rotors
05-08 F rotors and hubs
4.55 R gears
custom R 4 link with 2 bags per side (will explain later)
2" wheel spacers F
22" pete style wheels
Need advise on tires
custom bag set up on F
box full frame
R section of frame narrowed
custom steering for tighter turning radius (not quite sure how I will do this yet)
dual steering stabilizres
larger sway bars
urethene bushings and cab mounts
DJM dream beams
Body:
Custom 2 tone paint
suicide R doors
05-08 F bumper tweaked some
08-09 F air dam
05-07 F550 fender flares
08 tailgate w/ step
08 R bumper
05 harley headlights w/ HID
05 fog lights w/ HID
cowl hood
03 up dodge cab lights smoked LED
Smoked red LED tail lights
Recon line of fire LED under tailgate light
Recon smoked fender lights LED
Smoked LED 3rd brake light
Solid roll down R window (custom)
The Power:
MBRP 5" exhaust turbo back
S&B intake with custom ducting
Garrett GT38 turbo
headers
up pipes
Non EBV turbo pedestal
BD intake plenums
CFM+ turbo outlet/intake plenem inlets
Banks TechniCooler
CCV filter
Custom tuning
BD Stage 1 injectors
FASS 150 fuel lift pump filter and water seperator
Custom rebuilt auto or swap to 6spd manual (haven't decided)
Fluid dampner
Interior:
08 center console
white face gauges
autometer gauges for engine
re-dye dash
new carpet and headliner
Will add more as I make some final decisions on some things still up in the air
What Has been done
Exhaust
Intake
Cab lights
3rd brake light
tail lights
lockone   +1y
Sounds like a big project. There is alot of the things you have listed that are not necessary unless you just need/want to do them and some of the stuff doesnt go with other parts. Just dont want you to buy some parts and find that they will not work with others you may already have.
Let me know if you need some help/advise on the wheels and/or suspension and I will be more than happy to help you. We also have a parts truck if you need some replacement stuff you cannot find.
99350   +1y
As far as the suspension goes and the airbags I am planning and whatnot I use this truck to haul a fair amt. of weight. The last haul I did I crossed the scales just over 26K. I am not looking at having my truck lay frame with the bags just a little better ride.
What parts are you talking about that won't work together more detail for some advise would be great.
A lot of things will be complete custom made things. I have access to a full engine machine shop and regular machine shop so I will make the majority of all my parts or modify parts to work about the only prebuilt parts I am going to be buying is the engine and trans stuff and some exterior parts.
Should have the headlights, and other front end stuff next week then I will start modifying the 2 05-07 F bumpers I wish I could post a pic of the drawing I made of the F bumper to show what the plan is. Essentially I will cut the bottom half off the second bumper and combine it to the 1st to make it taller but add fillers to keep the holes the same size and shape as a normal one and then take a 2nd gen 08-09 air dam under it (abt. 6 in deep air dam, trying to keep air out from under the truck and)
I will get some pics up this week of what I have done so far and where I am starting from
