1988/98 dually project help!!
double_dees
hey guys im new to the dually scene and i need some help with my 1988 coverted to 1998. Truck is pretty much all 98 motor/tranny/interior/front end/box. Im having some issues with some things with this swap. My brakes seem like there backwards any help? My 98 dash heater selector is stuck on vent/floor and only blows air when selected on the highest function. Any help from anyone would be great and once the truck gets rollin ill be posting a build thread plans are to rock 22' alcoas laying frame.
P.S: By far this site kicks some royal pavement!!
BB
big bear
welcome from northeast ohio, cant wait for pics
lockone's avatar
lockone
Welcome to the site.
The blower function arm is probably broken and does not allow it to move back and forth to direct the flow of air properly.
double_dees
Its on a turn dial, im guessing on the 88 dash it was a slider, the whole 98 swap was done by someone else im just trying to go over everything and fine tune it up to my liking lol
someotherguy's avatar
someotherguy
88-98 all trucks in this body style, when equipped with A/C, use electric actuator motors, not cable sliders. However the motors may be different once the swap to the 95-up style controls came along - I've never bothered to compare part numbers; I can tell you that around 94 the size/shape of the blower motor resistor changed so the hole in the duct box changed to match it and the best way to accomplish that dash swap would have been to swap out the whole box, which would have brought along all the newer motors too.
Heat-only trucks had cable sliders but obviously you'd run into trouble trying to use any of these parts with A/C - you didn't tell us though if your truck has A/C. Even the late model heat-only trucks I've seen use cables; was gonna do an A/C conversion for a guy with a 2000 C3500 utility truck but he backed out when he realized just how much needed to be replaced including the engine harness (had no provisions at all for the A/C components), duct box, adding the condenser, cutting the holes in the firewall for the evaporator lines...
Anyway what Trevor said, the arm could be broken. I've also seen more than a few of the later model setups where the flap breaks inside the box, which sucks. If it's A/C equipped with electric actuators - the vent position actuator is the only one that has linkages on it, they get gummed up from the factory lube hardening and they quit sliding, making the functions work incorrectly. Check it out; this is the one on the far left of the duct box, which is just above the driver's side of the transmission hump. Also, control board being bad can cause this.
That it only blows air on the highest setting is either a bad blower motor resistor (most #1 common reason for this), or they left the old duct box in there and didn't hook up the resistor or the blower speed relays correctly (the number of them and the arrangement changed over the years, especially because 98 has 4 speeds and 88 has only 3.)
What's this about the brake lines?
Richard
BB
big bear
yea..what he said !! lol
double_dees
Thanks Richard on the info im going to have to look at this in more detail. See i didnt do the swap so im trying to clean up where someone has left off, im not to sure if it came stock with a/c. The truck has been pretty much swapped over to a 98 im talking front clip, box, engine and drive train as well as the interior. Engine in it has the a/c compressor. The truck came stock with the 454 and now has been swapped out for the 5.7 vortec. The selector for the heat does click each time i select a different mode so im thinkin that the selector its self is no good but i will be lookin at the other points you have pointed out too.
As for the brakes i think i might have found the issue i have 2 really really bad kinks in the brake line coming out of the master so im going to tackle that and see if thats the issue. Im hopen that they didnt try to mix the 88 set up with the 98 set up.
There are some other odds and ends ive gotta work out too like the door pane swap still has the 88 inner door handles but 98 everything else ie power windows and door locks.
But hey ill take all the info and help and hopefully pass on some helpful info along the was also.
