Dually Projects \  22.5 rim question
22.5 rim question
Dually Projects
views 1351
replies 4
spit on it   +1y
I just picked up a 85 chevy crew dually and would like to put 22.5 semi truck rims on it but I don't know what tires to go with . I would like to stay with a semi tire also ( lowest profile I can get ) . Anyone know what size tire I should get ? And I won't be slamming it to the ground . I want it to stay as close to factory ride hight as I can . Any info would be great !!!! Thanks guys !
bk2life   +1y
[quote="spit on it"] I would like to stay with a semi tire also I want it to stay as close to factory ride hight as I can . /quote]
there are zero low profile semi tires. you can not stay factory ride height with semi/big rig tires. it will lift your truck like 10 inches.
you have to have your 22.5s milled to a 22 inch tire then you can get a low pro 22 inch tire to do what you want. but no semi tires will work
tuckin12   +1y
Check into what car haulers run for tires, they are not low pros but smaller
jitteryguy   +1y
the car hauler run 19.5's. you'll have to mill em down to run stock suspension. there are taller tire's available for 22's but a very big tire will rerquire some lift.
spit on it   +1y
I don't have a problem lifting the front a coupe inches to match the rear . Would I be able to make something work then ?
