Dually Suspension \  77 c30 static drop help
Dually Suspension Dually Tech
views 6717
replies 7
diablo   +1y
im new to the dually scene but i just got a 77 c30 crew cab and i got a western chassis 6/8.5 drop kit spindle/spring /and flip kit.. my question is how can i get lower to the ground with out bags.., do i take out leafs in rear or add a shackle n hanger, or cut front coil ? what tire shuld i run on a 16 in rim with out lookin like rubber bands i want the full tire tucked look , i want as low to the ground as possible .its not a highway cruiser if i need a big notch and remove inner fenders and heater so be it i just need it slammed on the cheap and yet some what driveable . i know it sounds bad but it will only go to local cruise ins and shows 30 mile radious any info would be help full
snapdaddy   +1y
i have an 1980 cc dually i have the 6/8.5 drop on mine with the helper bags im running a 215/85/16 tire... mine is a camper special so i took out i think one overload and one leaf spring it gave me a total of 9 leafs and one over load in the back or maybe thats a total of 9 i cant remember its been a day or two... i think if you wanted to go lower it shouldn't be that hard to do im going to cut my front coils ill prob take 1/2 to 3/4 of one coil out just because it doesn't sit just right in the spring pocket that should drop me another 1/2 inch or so and the rear you could prob do a shackle in the back that will bring the rear down another 2 or 3 inch deepening on where you set it at... as far as tire size i would go with a smaller tire size i got a really good deal on my tires that i couldnt pass up when i get ready for new tire ill go smaller if im turing into a kinda steap driveway they will rub my firewall just a lil
diablo   +1y
thanks .. so it is possible to get 9 front if i cut a coil and around 12 rear drop if i take out leaves and a shackle kit and still be some what driveable
jcampbell1180   +1y
225/75/16's. 3" spindle, 3" coil, flip and drop shackle. I could stand to go about 1" lower all around, but I like my solid bed floor and the ability to be to get in and out of parking lots without getting high centered.
diablo   +1y
ok thanks heres what im workin with a i paid $1000 for this with a 454 and a 4sp . what is your guys frame clearance im lookin to get down in the 4 in range
jcampbell1180   +1y
I never really measured, but I know I can't slide my fat ass underneath it. I can fit your standard, 3-ton floor jack under the framerail with about 1"-2" to spare.
If I had to guess, I'd say I've got about 6"-7" of ground clearance...which is really about as low as I'd like to go on a 21' + truck.
wide load c-30   +1y
I think a step notch is mandatory when u start getting that low. The rear is easy there is shackles, hangers, removing leaves, etc. In the front either trim the coils or maybe a small z. The stock a/c will have to be removed or raised and clearanced. I would not mind if the front of my truck was one inch lower but I would have to modify my a/c some more and make custom shock mounts and that is with my drop shocks.
diablo   +1y
ya i was going to remove inner wheel wells and ac and heater box. i dont need all the fancy luxuries like ac n heat, windows rollup when im cold and down when im hot so il be ok lol
