Dually Suspension \  Which Air Lift Helper Bags
Dually Suspension Dually Tech
views 2511
replies 3
following 2
bigballer72   +1y
Finally got my 2000 Chevy Crew Cab Dually lowered. I used the 5/7 kit from DJM. The metal bump stop pad on the axle is smacking the angled portion of the notch when I hit any size bump in the road. Does those pads need to be removed or do I just need to install some helper bags, or both?
Which bags do I need to get? I'm being told different things from different people. There are two for my truck?
Air Lift 57216 - Air Lift Load Lifter 5000 Air Spring Kits or Air Lift 59202 - Air Lift SlamAir Plus Lowering System Kits
Any help would be great. Thank.
circuitguy   +1y
Yes, remove that large pad from the top of the rear axle. Youcan put a small bumper under the frame notch that will perform this job if needed. My 1997 Chevy Dually is the same way.
bigballer72   +1y
I removed the pads from the top of the axle, but which bags do I need to get? There are two for my truck and everyone says something different.
circuitguy   +1y
The rear air kit you need is the Belltech #5007, here is the link:
The air compressor kit with tank and guage you will need is the AirLift #25690, here is the link:
This is what I have on my current 97 Chevy Dually, I also used this system before on three other like trucks. I can tow anything and never it has let me down. I am sure there are other kits available for it but this is what has worked for me for many years.
