Dually Suspension \  What wheels will fit 2000 Chevy dually?
Dually Suspension Dually Tech
views 1774
replies 4
psychosurfer   +1y
Are there any other manufacturer (Ford/Dodge) that have bolt patterns and wheel spacing that are direct replacement onto a 2000 Chevy dually?
I have aftermarket aluminum wheels that the PO installed on it now. They are not my style and Im needing new front tires.
Please let me know if you know what will work or have a set you might like to sell. NOT interested in huge wheels.
lockone   +1y
On the 2000 Chevy trucks, you really need to stick with some thing that is a Chevy preferably in the 90-2000 range (8x6.5 pattern with 4.567 hub bore). Dodge will work but hub bore is too big as is the newer body Chevy wheels.
luv2xclr8   +1y
I put 19's (19.5's milled down by Trevor in post above)
on my Y2K and ditched my 16's. Best move I ever did.
They were a direct bolt on, so no adapters & no mods.
psychosurfer   +1y
Thanks for the info guys. On the 19's, will they clear with a static drop (5/7) and are there load range E tires that will work?
Thanks again!
circuitguy   +1y
I have the same truck and want to put the 19" wheels on it. What size tires should be used with the 19" wheels? It has a Belltech 5/7 drop with the frame notch and rear bags. I dont want big rubbing problems. Lmk...
