Dually Suspension \  "repost again" what size is the 82 dually axle tube ?
Dually Suspension Dually Tech
views 1213
replies 7
bodiedtaco93   +1y
i need to know the size of the duall axle tube
bk2life   +1y
chevy/ ford/ dodge/ import?
what axle?
can you post a pic of it?
and the tube as in the axle tube like 3" or 4" or 5" round? or the length of the tube like 18 inches long on each side?
tuckinuts   +1y
That is impossible to answer without knowing what you have. You know, like manufacturer.....Who made it.
Is it a GM corporate 10.5" 14 bolt, Dana ??, etc?
Even knowing which rear end you have there is a chance of being wrong . Because of the hodge-podge, no rhyme nor reasoning behind what GM did by using what ever was lying around / supplied by the cheapest vendor.
Best advise I can give you is use a large set of calipers or just do the math.... Take a tape measure, wrap it around the axle tube housing (where you're wanting the diameter), get the circumference (C). Divide that by Pi (3.142). That will give you it's approximate diameter (D).
C/Pi = D
Darrell
bodiedtaco93   +1y
87 dually stock axle
bodiedtaco93   +1y
i had all it posted but for some reason my thread got deleted , im going to cut axle tabs but truck is at home 700 miles away
comegetsome   +1y
Should be 4 inch but i have used 3 inch axle brackets with minor trimming
tuckinuts   +1y
If it's a Gm truck, 82 or 87, there's not one specific stock axle. Is it a Corporate 14 bolt, or a DANA 60 or 70?
It will be either 3.500 or 4.000 .
Darrell
bodiedtaco93   +1y
ok thanks and whats a good distance on how far apart should a parallel 4link bolt holes be at the axle
