Hello all I in need of some help I pick up a 89 R3500 it has the 454tbi th400 when I got the truck. It ran ok but the temp never went up and at low speed the heat worked but over 45 just blow cold. So I checked the thermostat it was stuck open so I replaced it now when I start the truck it has a high idle and when worm go to put it in gear. It dies on me I have replaced the map sensor and the injectors look like they are spraying way to much fuel. Any help would be great
someotherguy
Replace the coolant temperature sensor. Not the one-wire one on the head that is for the dash gauge, but the two-wire one on the intake by the thermostat. It tells the ECM what the coolant temp is. They fail in a way that reads colder than actual temp and cause over-fueling.
