ticking noise front drivers side need ideas 96 gmc
chango
my 96 has a clicking which sounds like its coming from the front drivers wheel it goes away when wet or turning left, i have jacked up front end but no click its almost like it has to have weight on it or its not the wheel, so far i have switched the wheels to opposite sides new wheel bearings turned rotors new pads greased front end cleaned abs sensors and reluctors, ive even checked driveline for bad ujoints im at a loss any ideas thanx
krewzlo's avatar
krewzlo
Make sure your wheel bearings are adjusted right. I had that before and my bearing was a touch loose. Tightened it up a touch and clicking went away
chango
i will do that thanx
someotherguy's avatar
someotherguy
Off-the-wall possibility, be sure the sheetmetal shield behind the rotor isn't bent at all.
Richard
chango
i bent it all back and away that was one of my first attempts lol another thing im gonna check is if the weight is hitting somewhere
someotherguy
You tried running it without the center caps on the wheels?
Richard
chango
i have not i will try that
Related Discussions in Dually Engine
