I just recently bought a 93 Mazda b2600i. I am about to purchase Nissan titan wheels i was wondering if its a direct bolt up? Also How i would go about lowering it? I dont want it too low for now since its my daily driver but one day hope for a bag and body drop . Any suggestions would greatly be appreciated thanks! and ill post some pics asap!
5thbsacharm
2004-2007 Titan Crew Cab LE, SE
17" 18"
2004-2007 Titan Crew Cab XE Titan King Cab XE 17" only
2008-2010 Titan Crew Cab LE Titan King Cab LE 20" only
2008-2010 Titan Crew Cab SE, XE, and PRO-4X Titan King Cab SE, XE, and Pro-4X
18" only
these are the rims i found will fit, hope it helps
CS
col. sanders
Thanks and welcome to the family, I myself am new to the B Scene. I ground down the tabs on the front and rear hubs you can see them if you pull one of your wheels off. I lowered the front a little over two inches by indexing the torsion bars and I also turned them down a tad. The rear has 3in blocks plus I took out the larger leaf. I would like it to sit lower but I am running a 225 45 18 tire I also chopped down the front and rear bumpstops too. Future plans are to buy different tires and bag the front maybe the rear or run air shocks. There is a lot of info here so take your time and do some reading.
