i need help plz
i need help plz
master_pain420
i have an 89 mazda b2200 i dont know if its the original motor but the carb on it i think is shot....i replaced the head gasket and new timin plugs wires oil thermostat and when i drove it for the first time after all that it seemed like it didnt want to pull and now it just sounds like its either chokin or floodin out but im not sure im still learning bout mazdas and if ne one could help me that would be great.....thanks
dropped90(justin)'s avatar
dropped90(justin)
sounds like the timing is off a tooth or two
-Justin
master_pain420
but the timin light i used said it was good though...could the light be wrong or wat? it ran fine until i did the work to it and someone helped me that said they knew wat to do and i dont think he did.
sounds a tooth off
master_pain420
and i how do i correct that? also....i went to flush the motor of all the water and there is no water comin out of the bottom of the motor wat does that mean?
bagged2.2's avatar
bagged2.2
shitty carb....lol
E
emjay
Where are you flushing it from? If you are flushing from the radiator it could be due to the fact that the thermostat would be closed.
To me your timing issue sounds like the timing between the crank and the cam is off by one tooth. the way to correct this would be to take the timing belt off and realign the cam and the crank.
master_pain420
thanks for the help...i talked to a friend of mine and he is chargin me ten buck to do it....he said the same as yall....thanks again i like this forum its better than the rest. again thanks.
