need help with 20s!
need help with 20s!
baggedmazda86 avatar
baggedmazda86
Does anybody know what i would have to do for me to lay on 20s??? I already lay on 17" caddys. i want a bigger wheel.
law#3 avatar
law#3
how did you get 17s on?
baggedmazda86
wat you mean? would i need to fab anything up in the front to lay 20s?
hunterw avatar
hunterw
are you body dropped? or plan on it? but if the answer is no. you can piecut your upper conrol arms and get drop spindles and lay out pretty easy. a 225/30r20 tire is like25.5 inches tall. so use that as a reference point. if you run the 225 30s you dont really need to tub your firewall. what i didwas put a 2x4 in between my wheel and firewall/stock tubs and llowered the truck to push it back some
baggedmazda86
oh i want to body drop it thos winter. so when i bd it imma have to tub my firewall. and ima try to get my lower conrols thid winter to.
hunterw avatar
hunterw
Man I would honestly body drop it first and see where everything is gonna be. And then from there bag it. When you bd you will have to tub firewall. Move clutch cylinder,run a high offset wheel combo, notch the frame for a good size bag to fit so you get enough lift. The lower control arms aren't too much of the issue. Usually its the upper. Nd also do you want a lot of camber or little to none? Check my build log its called juanita. Could be pretty helpful
baggedmazda86
Aite man thanks
selfbuiltrods avatar
selfbuiltrods
HUNTER IS ON TOP OF THINGS!
hunterw avatar
hunterw
lol thanks SBR this is actually a part i have exp. in haha.
that was the start of the bagging of my truck . and then followed the bd. it would have been easier to BD it first IMO. and my next build i plan on either doing the bd first or at the same time.
