Looking to buy a 1992 B2600i. Few questions.
taurencollinson@gmail.com's avatar
tcollinson's avatar
tcollinson
Hey guys,
Looking into buying this beaut':
I was just wondering. Did some of the 1992's come with a mitsu engine? I've read otherwise. He's told me that it is the stock engine in the truck but I dunno.
Also, are the mazda and mitsu 2.6's easy to work on and are they both reliable? I've read good things about the mazda but I've read about overheating issues with the mitsu?
Just trying to be cautious with my next purchase. I've had terrible luck with my last two buys and don't want to end up buying a vehicle that is going to burn another hole in my pocket.
Thanks
tcollinson's avatar
tcollinson
I also forgot to add. My grandfather has an B2600 that he is willing to sell cheap. It is a 1996 with very low kilometers and has been babied. Can the mazda b2600 of that year mate with the transmission of a 92?
Thanks in advance.
9
91_2600i
Welcome to the forum!
In the states, the B2600 was made in 87 & 88 with a carbureted "Mits" engine. Starting in 89, they had a Mazda engine (G6) that was fuel injected. I have read that Mazda bought the engine tooling and/or rights from Mitsubishi for it, but I don't know if that is true. The trucks were only built here through 93. I would be real surprised if that truck has a Mits engine because the Mits was never fuel injected in these Mazda trucks in the states. The "Bubble Hood" would also be telltale sign of the Mazda G6 injected engine in the states.
If you look at most all of the components for the G6 engine (Mass AirFlow, Distributor Cap, ECM, Solenoids, & many others) most of them were made by Mitsubishi. So I think the owner has seen Mitsubishi plastered all over those components and assumed it was a Mitsubishi engine. But it is considered a Mazda engine.
They are very durable and reliable but have two Achilles tendons. The ECMs and fragile heads if overheated. If you don't overheat it and keep an eye on the ECM, it would probably make a reliable truck. Many owners get a bad ECM but miss-diagnose it and end up replacing other components before finally figuring out it's the ECM.
If you double check the engines (probably both years use G6) and then check the transmissions (92 vs 96.... almost certain they would be the same too) then in all likelihood, they are the same and will swap. But do your homework - things could be different down under!
I bet a fellow Aussie will be along to to confirm (or deny!)
