General Discussion \  I NEED HELP PLEASE
I NEED HELP PLEASE
General Discussion
views 1878
replies 16
following 6
yes_im_slammed253   +1y
So i took the bed off my mazda b2000 87, and i cut the extra trailer wire off and now my dash,front and rear parking lights do not work. however there is still enough of the wiring to re connect but i dont know which ones to connect to which
thermus   +1y
You can't match the colors back up?
sincitylocal   +1y
Check your fuses.
well there is 2 yellow, 2 green, i joined those back together, but there's 2 maroon, and 2 white colored wires, part that im confused about is do i connect the maroon to the white? Fuses are good, the wires are located on the rear passenger side right above the leaf springs on the frame..
Cusser   +1y
Guess what: dash, parking lights, and tail lights are ALL on the same circuit from the headlight switch. Likely you blew that fuse when you cut the wires.
Look for a red 10 amp fuse labeled "TAIL" in the fuse box (lower dash, left side of dash).
iight thanks ill try that asap and get bak to u on that.
hey your completely right my fuse was blown wen i cut those wires, but the only problem that i have now is i replaced the fuse and as soon as i turned the switch for my headlights it blew out again. so i taped up the wires just to make sure they werent touching the frame or anything like that and i put another new fuse and it still blows immediately wen i turn on my headlights. what causing this PROBLEM and how do i fix it??? please and thank you..
thermus   +1y
There is a power wire touching ground or bare metal somewhere. Start chasing wire and look for bare spots.
86baggedmazda   +1y
hey bro i just had to replace the hole harness from front the back cuz it was melted together so i can feel ur pain with the wiring where u located maybe i can help u out
i live in puyallup washington, yea im kinda fed up wit this whole wireing crap, its annoying not being able to drive at night. but but yea that would be nice if i could get some help with it, let me know if its worth yur drive out here, i got a full fridge of budlight and a carton full of smokes.
