Hi from Colorado
Hi from Colorado
kai87b2200
Picked up my first b series yesterday and plan on doing a full restomod.
Spent $250 because he thought it had a bad tranny but it turned out to just be the clutch so im happy with it
mymmeryloss's avatar
mymmeryloss
Welcome to the forums. I saw this on Craig's list. Where are u located? I'm in Grand Junction.
Sent from my QMV7A using Tapatalk
kai87b2200
Im located just outside ft carson in the springs
mymmeryloss
Right on.
What are your plans for the truck?
Sent from my iPhone using Tapatalk
kai87b2200
Im looking to mostly restore it and clean her up then build the engine just a bit to try and have a bit more fun. =D
mymmeryloss
Sounds great! Good luck
chaserjohndoe's avatar
chaserjohndoe
A Weber and header is about the only performance add on for these little trucks. And that's just for serviceability and simplicity. it might add a whole 20 hp if you are lucky.
You can use the probe/mx6 turbo, but that is a little more complicated. There are write ups around here somewhere to do it. And will net you more power depending on the setup.
kai87b2200
Nice thanks for the info
