General Discussion \  Bad floors need help please.
General Discussion
views 1067
replies 7
1986b2000   +1y
Anyone know of websites where i can buy replacement floor pans of an 86 reg cab? Any info would be awesome.
1986b2000   +1y
Or maybe just buy sheet metal and just weld in leaving tranny tunnel if possible? I don't really think all the indent are important as long as the floor is the same general shape i should be fine right?
chaserjohndoe   +1y
Ask VSAWMike, he just cut open a excab the front floors should be the same.
mymmeryloss   +1y
You need to do some bracing underneath or it wont be sturdy at all.
Sent from my iPhone using Tapatalk
1986b2000   +1y
Thanks ill ask him. And more in depth with the bracing please. is that as is or if i replace with flat sheet metal?
mymmeryloss   +1y
Yeah if u do it with flat then use 1x1 square tubing to build a frame under it.
lowlyfe   +1y
Look at my build thread. I cut the rotted floor pans out and welded in flat sheet metal without bracing underneath and its real firm. The body mount is right under there so that acts as a large brace, you may have to cut your body mount off also and cut the spot welds off, then weld that to the sheet metal floor pan if the cancer has spread that far.
1986b2000   +1y
awesome thank you all for the advice.
