General Discussion \  Gas gauge doesn't work on my 1986 B2000
General Discussion
views 832
replies 1
following 2
gunderthewonder   +1y
Is here a fuse for the gas gauge? If not... where is the sending unit?
Cusser   +1y
Yes, there is a fuse, believe it is called "Meter".
The sender is on top of the gas tank, under the bed. If you ground out that wire, fuel gauge should read full if the gauge is OK. You may need to raise the truck bed for access, see below.
" target="_blank
